メインコンテンツにスキップ
Logitech UE MegaBoom Speaker Replacement
必要な工具と部品
  1. Logitech UE MegaBoom Speaker Replacement, Outer Mesh: 手順 1、 3の画像 1 Logitech UE MegaBoom Speaker Replacement, Outer Mesh: 手順 1、 3の画像 2 Logitech UE MegaBoom Speaker Replacement, Outer Mesh: 手順 1、 3の画像 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Speaker Replacement: 手順 2、 3の画像 1 Logitech UE MegaBoom Speaker Replacement: 手順 2、 3の画像 2 Logitech UE MegaBoom Speaker Replacement: 手順 2、 3の画像 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Speaker Replacement: 手順 3、 2の画像 1 Logitech UE MegaBoom Speaker Replacement: 手順 3、 2の画像 2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Speaker Replacement, Battery: 手順 4、 1の画像 1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
  5. Logitech UE MegaBoom Speaker Replacement, Speaker: 手順 7、 2の画像 1 Logitech UE MegaBoom Speaker Replacement, Speaker: 手順 7、 2の画像 2
    • Insert a opening tool between the grating and the body of the speaker
    • Pry up allowing the tabs to pop out of place.
    • There will be an audible sound when the tabs have begun to pop out of place.
    • Apply the same procedure to the grating covering the second speaker.
  6. Logitech UE MegaBoom Speaker Replacement: 手順 8、 2の画像 1 Logitech UE MegaBoom Speaker Replacement: 手順 8、 2の画像 2
    • Use a opening tool to push the thin metal rod located on the side of the speaker out.
    • Using needle nose pliers grasp the rod and pull the rod out of the speaker until fully removed.
    • Remove the remaining three rods.
    • One is located on the same side and two are located on the other speaker.
  7. Logitech UE MegaBoom Speaker Replacement: 手順 9、 3の画像 1 Logitech UE MegaBoom Speaker Replacement: 手順 9、 3の画像 2 Logitech UE MegaBoom Speaker Replacement: 手順 9、 3の画像 3
    • Insert a opening tool between the speaker and the base
    • Pry up allowing the speaker tabs to pop out of place
    • Find and disconnect the wire from the motherboard by pulling in an upward motion.
    • Apply the same procedure to the second speaker.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Oscar Ambriz
メンバー登録日: 09/27/17
958 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G2
4 メンバー
14のガイドは作成済み
7 件のコメント
Thank you! I was able to glue one of the passive radiators back in place.
Nick Johnston - 返信
Where can I find a speaker replacement? Thanks for your time
Aldrynaldryn - 返信
I’ve got the same issue. Where can i find the speaker replacement?
Fred BlacKshadow - 返信
For those looking for replacement speakers - either directly from Logitech ( $$$ ) or find a broken one on eBay that’s been water logged or some such thing and recover the speakers from that (since they are waterproof speakers)
Thanks for the article - turns out one of my speaker grills had popped loose and was imitating a blown speaker!
Glenn Griffin - 返信
yes! same issue!
i bought a replacement speaker (which i still have if anyone is looking), but it was a speaker grill stopper that had come unglued and vibrated - sounding exactly as if a blown speaker or radiator.
sweetrobot -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 156
今までの合計 25,261
