はじめに
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom power button.
必要な工具と部品
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Locate the end of the speaker which contains the power button.
Grasp the outer rim of this end cap and pull in an upward motion.
ある他の人がこのガイドを完成しました。
3 件のコメント
that would be a negative unless you really know what you are doing and can waterproof it
