はじめに
This guide will assist you with the removal and replacement of the Logitech UE Megaboom motherboard.
必要な工具と部品
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Insert a opening tool between the grating and the body of the speaker
Pry up allowing the tabs to pop out of place.
Apply the same procedure to the grating covering the second speaker.
2 の人々がこのガイドを完成させました。
