メインコンテンツにスキップ
Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
必要な工具と部品
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 手順 1、 3の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 手順 1、 3の画像 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 手順 1、 3の画像 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 2、 3の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 2、 3の画像 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 2、 3の画像 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 3、 2の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 手順 4、 3の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 手順 4、 3の画像 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 手順 4、 3の画像 3
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 5、 3の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 5、 3の画像 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 6、 2の画像 1 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 手順 6、 2の画像 2
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Oscar Ambriz
メンバー登録日: 09/27/17
958 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G2
4 メンバー
14のガイドは作成済み
10 件のコメント
How can I purchase this part being replaced thanks
Joseph Anderson - 返信
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - 返信
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - 返信
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 87
今までの合計 11,331
