メインコンテンツにスキップ
Logitech StreamCam (‎960-001286) USB-C Cable Replacement
必要な工具と部品
  1. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, USB-C Cable (board-to-computer): 手順 1、 2の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, USB-C Cable (board-to-computer): 手順 1、 2の画像 2
    • Be mindful of keeping the lens glass away from abrasives when disassembling. Turn the camera over and use your plastic spudger (pry tool) to pop out the plastic ring obscuring two small screws.
    • NOTE: many fixers may find that replacing only the distal USB-C plug is needed. In that case, you needn't open the camera or replace the cable -- just skip to the wiring explanation in step 4, and get a new USB 3.x type-A or type-C male plug.
  2. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Removing cable-housing retention: 手順 2、 3の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Removing cable-housing retention: 手順 2、 3の画像 2 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Removing cable-housing retention: 手順 2、 3の画像 3
    • Once the screws are removed, the retention ring easily separates from the cable moulding with firm prying or pulling pressure. It's a C-clip with some light adhesive facing outward.
    • After the retention clip is out, peering into the housing will reveal two identical 000 screws that hold the camera subframe to the outer shell. Remove these (they'll easily shake out if not pulled out with your screwdriver's tip).
  3. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Disconnect USB-C cable from board: 手順 3、 2の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Disconnect USB-C cable from board: 手順 3、 2の画像 2
    • With the retention ring off, you can advance the cable moulding into the housing, and the entire camera subframe assembly should freely disengage from the outer shell.
    • The cable's connection to the board is two-fold: unscrew the single grounding cable, then disengage the white plug by squeezing the wide surfaces with your thumb and forefinger then gently pulling outward.
    • The entire cable may then be pulled outward, through the outer housing/shell port where the cable retention clip was fastened. (The white plug can be slightly manipulated to fit through.)
    • The connector is a JST GH 1.25 10-pin. JST is the manufacturer, GH is the series; 1.25 is the pitch, the contacts being 1.25mm apart. (Thanks to comment by Oleg Vin for noting the type.)
    • Fixers replacing the entire cable may choose to solder a new JST GH connector to their new cable before disassembly, reducing the time the camera sits in pieces. (Reuse the original ground wire for the cable sheath/shielding.)
  4. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Understanding the wires: 手順 4、 2の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Understanding the wires: 手順 4、 2の画像 2
    • 2024.03.04 Warning: Due to reports and my own experience of failure to achieve 60fps, I believe the SSTX and SSRX pinouts are inverted. I will experiment and update the guide ASAP with any corrections.
    • 20240310: swapping 10 with 9, and 7 with 6 (polarity reversals) has given me 1080 60fps on Win 10 with Logitech Capture, but now my Linux PC doesn't recognize the camera.
    • In this guide, a 6-foot USB-3.0 extension cable (female and male type-A plugs) was the donor part. The female plug was cut off with several inches of cable, so that it could be repurposed; the male end and cable is used in this repair.
    • Researching USB 3.0 cable wiring, SSRX+ and SSRX- appeared mapped to yellow and blue, respectively. With the donor cable used here, however, continuity testing proved unexpected wire color deviation. SSRX+ and SSRX- as pictured in the accompanying donor cable image yielded a successful camera repair.
    • If the distal USB-C plug of the original cable is the only defect, you may alternatively or preferentially choose to replace it with a USB 3.0 type-C or type-A plug -- rather than replacing the entire cable. You can then retain the sturdy original retention collar and greatly simplify the soldering work.
  5. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Joining the cable and board connector: 手順 5、 2の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Joining the cable and board connector: 手順 5、 2の画像 2
    • Soldering is the most challenging task of this repair, but beyond the scope of this guide. Always ensure adequate ventilation, and use respiratory and eye protection.
    • The soldering results displayed in this guide are amateur and achievable by those with intermediate skills. Practice and patience are the key elements of success.
    • After soldering, use a multimeter or stand-alone continuity tester to verify that each pin of the connector has continuity with only the expected USB plug contact, as mapped in the previous step.
    • Each twisted pair of the cable has its own shielding that must be joined and linked to the black wire of board connector pin 8.
  6. Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Installing the repaired cable: 手順 6、 3の画像 1 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Installing the repaired cable: 手順 6、 3の画像 2 Logitech StreamCam (‎960-001286) USB-C Cable Replacement, Installing the repaired cable: 手順 6、 3の画像 3
    • Three screws hold the inner block. Removing this eases the task of threading through the board connector and insulated soldering work.
    • Not pictured is application of insulation to the soldered connections. This is necessary to prevent short circuiting and equipment failure. Options include heatshrink tubing, liquid electrical tape, or hot glue, among other approaches.
    • Cable retention and strain relief is created with hot glue as pictured. Sugru is recommended as a clean, strong, and aesthetically pleasing alternative.
    • The hot glue was applied two-fold: within the housing (through the rear cutout), then at the C-clip flange. The C-clip was screwed down atop the second glue application while it was still cooling.
終わりに
To reassemble your device, follow the initial instructions in reverse order. Pat yourself on the back for keeping this camera out of the waste stream!
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brian
メンバー登録日: 08/12/16
459 ポイント
1ガイドが承認済み
33件のガイドコメント
Hi Brian, thanks very much for this guide. Do you know where I can get a replacement cable for the cam? I haven’t been able to find any online? Thanks again.
Z
zaskif - 返信
You’re welcome, Zaskif. I made a comment attached to the guide, but it looks like it’s hidden… I reached out to Logitech support, and they confirmed that they don’t sell a replacement cable for the StreamCam. It’s a crazy bad look for Logitech, since it appears damage to the distal USB-C connection is a relatively common issue (that’s why I made the guide in the first place). “Support” said the only recourse is to replace the whole camera.
I’m in the middle of using a continuity tester to determine the pinout of the header, as it corresponds to the USB-C pins. Then I’ll wire the header plug to a DIY breakout female USB-C port, so I can use a USB C-to-C male-to-male cable I got for less than $10 online. Until I can succeed, I think the only other way for an accessible repair is to get a “for parts” camera that’s damaged in a different way, so that you can harvest its intact cable.
Brian -
I see, I’ve just seen your comment. Logitech has obviously thought this through! Such a shame they don’t even sell replacement parts for the cam on their website, knowing very well this is a common issue. I will probably end up selling it as “damaged”. Thanks very much for your response.
zaskif - 返信
Hi Brian, any luck with the cable pinout? I’d be interested as i have a USB C Female part I could use as you described.
Manuel Guijarro - 返信
No, Manuel, not really. I think I traced the board connector pins to the male USB-C end pins, but I don’t know enough about electronics engineering to know whether the Logitech cable has special resistors or other circuitry embedded in the distal plug. I’m anxious that assuming otherwise will fry the camera or a computer’s USB port. So, I’m on the lookout for a camera for sale that’s damaged in a different way, so I can harvest the intact cable, do further testing, repair and give an update here.
Brian -
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 124
過去 30 日: 501
今までの合計 18,900
