メインコンテンツにスキップ
Logitech Spotlight Battery Replacement
必要な工具と部品
  1. Logitech Spotlight Battery Replacement, Removing the back cover: 手順 1、 2の画像 1 Logitech Spotlight Battery Replacement, Removing the back cover: 手順 1、 2の画像 2
    • Removing the back cover :
    • The back cover is gluded on back middle and lower side. So it's much easier to rub in from top edge.
  2. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 手順 2、 3の画像 1 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 手順 2、 3の画像 2 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 手順 2、 3の画像 3
    • Try to tick out the wire of the battery to get more space.
    • Cut out the yellow tape of battery.
    • Desoldering the two wires connecting the battery to the board. Carefully don't touch the the positive and negative terminals on the same time for security.
  3. Logitech Spotlight Battery Replacement, Pull out the battery: 手順 3、 1の画像 1
    • Use pliers to clamp the board on the battery and pull the battery out. The battery is glued on the mainboard, and the battery is too long for back hole. So it's no easy to pull out.
  4. Logitech Spotlight Battery Replacement, Solder the new battery: 手順 4、 2の画像 1 Logitech Spotlight Battery Replacement, Solder the new battery: 手順 4、 2の画像 2
    • The original battery size is 3.9mm x 8mm x 36 mm. For ease of installation, I get a smaller battery with size 3.5mm x 8mm x 29 mm.
    • Put the new battery into the battery hole, and solder the new battery wires with the original wires. And use polyimide tape to cover the wiring point for safety .
  5. Logitech Spotlight Battery Replacement, Cover back the back cover: 手順 5、 1の画像 1
    • Clear out the original clue on the two sides and put some clue on. Then Cover back the back cover.
終わりに
作成者
1人の作成者と共同作成されました。
Leo Hsi
メンバー登録日: 08/09/24
121 ポイント
1ガイドが承認済み
1件のガイドコメント
Potresti indicare tipo di batteria e dove comprarla? grazie
Sandro - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 48
今までの合計 522
