メインコンテンツにスキップ
Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement
必要な工具と部品
  1. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 手順 1、 3の画像 1 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 手順 1、 3の画像 2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: 手順 1、 3の画像 3
    • To remove the plastic cover. You want to use the plastic opener and starting with corners.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use it carefully in order to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Carefully remove the cover as it can be very fragile
  2. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 2、 3の画像 1 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 2、 3の画像 2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 2、 3の画像 3
    • Remove eight 10.5 mm Phillips #1 screws from the cover.
    • Insert a metal spurger at the corner to help loosen the cover.
    • There is still glue sticking the front cover and the back cover together.
    • Starting with corners, lift up the cover slowly and carefully.
    • Do not pull too hard when removing the cover. There are wires connecting between the battery and the circuit board.
  3. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 3、 2の画像 1 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 3、 2の画像 2
    • Identity the speaker cover, and remove four 4.5 mm Phillips #1 screws.
    • Lift up the cone. It should be removed very easily by hand.
  4. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 4、 2の画像 1 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: 手順 4、 2の画像 2
    • Remove four 5.2mm Phillips #1 screws that are securing the circuit board.
    • Unplug the connecting wire from the circuit board. Carefully lift up the circuit board.
    • Same as step 3, remove four 4.5 mm Phillips #1 screws from the speaker cone.
終わりに
作成者
2人の作成者と共同で作成されました。
junyi yang
メンバー登録日: 07/11/18
109 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018人のメンバー
IUPUI-WILSON-SU18S4G4
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,239
