メインコンテンツにスキップ
Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement
必要な工具と部品
  1. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 手順 1、 3の画像 1 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 手順 1、 3の画像 2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 手順 1、 3の画像 3
    • To remove the plastic cover, use the plastic opening tool at the corner of the device.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Caution: Carefully remove the cover as it is easy to break.
  2. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 2、 2の画像 1 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 2、 2の画像 2
    • Remove the eight 10.5 mm Phillips #1 screws securing the cover.
    • Remove three 5.2 mm Philips #1 screws securing the dock.
  3. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 3、 2の画像 1 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 3、 2の画像 2
    • Use the metal spudger to loosen the front cover to get into the inner part of the device.
    • Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure to carefully lift up the front cover from the back cover.
    • There are wires connecting to between battery and the cover.
  4. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 4、 2の画像 1 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 4、 2の画像 2
    • Identify the small circuit board attached to the dock adapter cover.
    • remove two 2.5 mm Phillips #1 screws at the circuit board.
  5. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 5、 2の画像 1 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 手順 5、 2の画像 2
    • Carefully take out the dock adapter cover from the device.
    • It might needs few try to pull out the small circuit board.
    • Take out the broken dock adapter cover and replace with the new one.
終わりに
作成者
3人の作成者と共同で作成されました。
ali alhashim
メンバー登録日: 07/18/18
121 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018人のメンバー
IUPUI-WILSON-SU18S4G4
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 827
