この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
はじめに
After some time left mouse click fails. This results in unintended double clicks or drag and drop. This can be solved by disassembling the mouse and folding a metal part.
Thanks to Kyler's Studio for the tutorial I initially followed.
必要な工具と部品
On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
This step isn't necessary, but it makes it easier to work on the mouse.
This helps to avoid losing the white piece.
Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
To reassemble the mouse, follow the instructions in the reverse order.
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
94%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
8件のガイドコメント
merci , ca vient de sauver ma Revolution
Avec plaisir. J'en suis ravi :)
Samuel Colin - 返信 共有
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - 返信 共有
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
