メインコンテンツにスキップ
Logitech Performance MX Disassembly
  1. Logitech Performance MX Disassembly, Remove the Mouse Feet: 手順 1、 2の画像 1 Logitech Performance MX Disassembly, Remove the Mouse Feet: 手順 1、 2の画像 2
    • Peel off the three thin, plastic mouse feet on the bottom of the mouse. Make sure to carefully remove the adhesive along with the pad.
    • Use a thin flat object such as a flathead screwdriver to help remove if necessary.
  2. Logitech Performance MX Disassembly, Remove the First Four Screws: 手順 2、 2の画像 1 Logitech Performance MX Disassembly, Remove the First Four Screws: 手順 2、 2の画像 2
    • Using a screwdriver, unscrew the four screws that were under the mouse feet.
    • Remove the battery from the mouse if not done already.
  3. Logitech Performance MX Disassembly, Separate the Top and Bottom: 手順 3、 3の画像 1 Logitech Performance MX Disassembly, Separate the Top and Bottom: 手順 3、 3の画像 2 Logitech Performance MX Disassembly, Separate the Top and Bottom: 手順 3、 3の画像 3
    • Gently pull the top of the mouse off from the base, making sure the wires and components are in place.
    • Carefully pull out the white enclosure from its port to safely take the top apart from the bottom.
  4. Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: 手順 4、 2の画像 1 Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: 手順 4、 2の画像 2
    • Pull out the plastic pin in-between the scroll wheel and the battery enclosure and pull up on the scroll wheel base to remove.
  5. Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: 手順 5、 2の画像 1 Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: 手順 5、 2の画像 2
    • Remove the 2 small springs underneath the scroll wheel base.
    • Unscrew the four screws holding the battery capsule onto the PCB.
  6. Logitech Performance MX Disassembly, Unplug the Ribbon Cable: 手順 6、 2の画像 1 Logitech Performance MX Disassembly, Unplug the Ribbon Cable: 手順 6、 2の画像 2
    • Unplug the ribbon cable from the circuit board. Be careful to not remove the cable’s locking mechanism.
  7. Logitech Performance MX Disassembly, Remove Scroll Wheel Support: 手順 7、 2の画像 1 Logitech Performance MX Disassembly, Remove Scroll Wheel Support: 手順 7、 2の画像 2
    • Unscrew the four screws to take out the black scroll wheel support in the center and the two black pads that lie on both sides of the support.
  8. Logitech Performance MX Disassembly, Pull Up Circuit Board: 手順 8、 2の画像 1 Logitech Performance MX Disassembly, Pull Up Circuit Board: 手順 8、 2の画像 2
    • Pull the circuit board up to find the on and off switch. Take out the clear plastic bit that held the springs.
  9. Logitech Performance MX Disassembly, Disassembly Finished!: 手順 9、 1の画像 1
    • All parts should be visible to repair or for replacement.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Harika Vuppalapati
メンバー登録日: 11/23/21
259 ポイント
1ガイドが承認済み
コメント 1 件
Although useful, sadly this guide does not show how to disassemble the upper parts where the 3 switches for zoom, back and forward are located. Step 3 is the only place that shows this area, but only focuses on the disconnection of it.
Phil Millard - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 34
過去 30 日: 118
今までの合計 3,405
