この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the top cover of your Logitech MBJ58 Mouse is damaged or needs to be replaced, this guide will help you replace the top cover. By replacing the top cover, damage can be removed, comfort can be added, and the aesthetics of your mouse can be increased. For this repair, no special skills are required and should be a straightforward fix. When reattaching the new cover, be sure to not strip the screw and crack the cover by using too much pressure.
必要な工具と部品
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
3 の人々がこのガイドを完成させました。
