この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You will learn how to remove and install the support spring.
必要な工具と部品
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Locate the scroll wheel on the mouse.
Grab the scroll wheel with your thumb and index finger.
Gently lift up, to remove the scroll wheel from the mouse.
Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
6 の人々がこのガイドを完成させました。
