メインコンテンツにスキップ
Logitech M570 Wireless Trackball Mouse Microswitch Replacement
必要な工具と部品
  1. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Remove the screws: 手順 1、 1の画像 1
    • Unscrew 5 screws, which are partially hidden. Three screws are located under the rubber buffers and one in the battery compartment under the sticker (which should then be loosened beforehand).
    • You can simply push the blue trackball out of its holder. You should also do this occasionally and clean the opening.
  2. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: 手順 2、 2の画像 1 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: 手順 2、 2の画像 2
    • After the screws are loosened, the housing can be easily removed. The space for the blue ball is made of its own piece of plastic. The circuit board is held in place with a few screws.
  3. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Detach trackball holder from circuit board: 手順 3、 1の画像 1
    • Lift the gray latch and pull the flat cable out of the connector. The trackball holder can then be placed to the side.
  4. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: 手順 4、 2の画像 1 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: 手順 4、 2の画像 2
    • Unscrew four Phillips screws (orange) and lift circuit board out of housing, being careful with the wires holding the battery, but these can be lifted out of the housing without further unscrewing.
    • The switch for switching on should not be lost in the process (see second picture)
  5. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Microswitch replacement: 手順 5、 1の画像 1
    • Properly desolder the microswitch (green) at its three contacts
    • Solder in new microswitch, making sure that it sits flat on the board.
  6. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Reinstall the circuit board: 手順 6、 1の画像 1
    • Make sure that the small circuit board with the two buttons with the hole in the middle (green) is placed over the holding pin. Then it is in the correct position.
終わりに
Work through the steps in reverse order to reassemble your device.
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
shingleさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Peter Scholl
メンバー登録日: 06/26/21
1,818 ポイント
7のガイドは作成済み
5件のガイドコメント
Where I would been able to buy the microswitch?
Torpedo Javi - 返信
I soldered it out from an old mouse... but I think you will also get it on ebay
Peter Scholl -
This guy shows replacement switches fixing a newer version of same trackball(I think). It has a built in battery now.
Replacement switches he used from ALIEXPRESS.
I think I'll try those. I've had switches lose there mechanical springy-ness and also get where they don't work reliably on 2 or 3 trackballs.
https://www.aliexpress.us/item/325680110...
https://michael.stapelberg.ch/posts/2021...
Spruce Moose Tomato Juice - 返信
Ich konnte bei mir im Fundus eine Maus (DELL M-UVDEL1) finden, welche einen sehr ähnlichen Taster verwendet; diesen konnte ich erfolgreich verpflanzen :-)
Michael-01 - 返信
Danke für die Rückmeldung - freut mich, wenn die Infos Menschen auf Ideen bringen bzw. weiter helfen. Viele Grüße!
Peter Scholl -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 14
過去 30 日: 55
今までの合計 5,051
