メインコンテンツにスキップ
Logitech M515 (Couch) Mouse
必要な工具と部品
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: 手順 1、 1の画像 1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: 手順 2、 1の画像 1
    • Remove the single Phillips screw located between the battery sockets.
    I used this guide to open my Logitech M-RCQ142 (that looks almost the same). Logitech changed the one screw-system to four screws located in the same place, so this guide worked perfect. Thanks for sharing!
    WillemPirquin - 返信
  3. Logitech M515 (Couch) Mouse: 手順 3、 1の画像 1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    doesn't go deep enough. need to fix right switch. part numbers are required.
    Lewayne Gragert - 返信
    I doubt you can get parts for this, it's not a high ticket item.
    Anna Sweetnam - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Anna Sweetnam
メンバー登録日: 04/08/10
232 ポイント
1ガイドが承認済み
4 件のコメント
I got to step 3. where is step 4?
hawaii50 - 返信
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - 返信
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - 返信
M545 works similarly btw
Adri Idzwan Mansor - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 4,918
