はじめに
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
  1. Remove the battery hatch and batteries.
    • Remove the battery hatch and batteries.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Remove the single Phillips screw located between the battery sockets.
    • Remove the single Phillips screw located between the battery sockets.
  4. Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
まとめ
4 の人々がこのガイドを完成させました。
Anna Sweetnam
メンバー登録日: 2010年04月08日
232 ポイント
1ガイドが承認済み
I got to step 3. where is step 4?
hawaii50 - 返信
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - 返信
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - 返信
統計データを表示:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 76
今までの合計 3,278
