はじめに
Logitech M510 のスクロールホイールが壊れたり、摩耗したりした場合は、このガイドを使用して交換してください。 電子機器を扱うときは、必ずワイヤレスUSBプラグを抜き、静電気を放電するか、静電気防止手袋を使用してください。
必要な工具と部品
デバイスを再組み立てする際は、これらの修理ガイドを逆の順番に従って作業を進めてください。
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
3 件のコメント
Thanks for the guide. My scroll wheel just needed a bit of cleaning to get it to work properly. Only cost me 15 min of work productivity and I’m back up and running :)
Thank you for this! I wasn’t sure if there were screws hidden under the rubber feet, so I’m so glad I checked before tearing things apart. 2 simple screws in the battery compartment is simple enough, but I needed to do a full teardown and there was one more screw inside holding the board to the base of the mouse. I also had to mess with the ribbon cable for the optical sensor and that’s fine, but if you need to do the same, it will be much easier to remove the sensor and leave the ribbon attached.
I’ve had this mouse for years and love it, but mine has a semi-defective middle-click button that means I often have to mash the button for it to register as a click. I’ve learned a little bit recently about tactile momentary switches (buttons) for a project I’ve been working on, so my goal was to replace it. Once I got it all apart, I simply desoldered the old button and replaced it with another one I had. Now it works perfectly!
Symptoms for me were the scroll wheel would only scroll down, not up. At first I thought driver or software, but then realized it was just filthy with 8 or 9 years of hair and dust! After dissassembly and careful cleaning, works like new.
