メインコンテンツにスキップ
Logitech M215 Top Cover Replacement
必要な工具と部品
  1. Logitech M215 Top Cover Replacement, Remove the battery cover: 手順 1、 3の画像 1 Logitech M215 Top Cover Replacement, Remove the battery cover: 手順 1、 3の画像 2 Logitech M215 Top Cover Replacement, Remove the battery cover: 手順 1、 3の画像 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Top Cover Replacement, Remove old battery: 手順 2、 1の画像 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Top Cover Replacement, Top Cover: 手順 3、 2の画像 1 Logitech M215 Top Cover Replacement, Top Cover: 手順 3、 2の画像 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Top Cover Replacement: 手順 4、 1の画像 1
    • Pry the top cover off. You may need to use a pry tool to help.
終わりに
作成者
4人の作成者と共同で作成されました。
Hannah Pate
メンバー登録日: 01/30/15
1,734 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S1G1
4 メンバー
28のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 2,666
