メインコンテンツにスキップ
Logitech M215 Lens Replacement
必要な工具と部品
  1. Logitech M215 Lens Replacement, Remove the battery cover: 手順 1、 3の画像 1 Logitech M215 Lens Replacement, Remove the battery cover: 手順 1、 3の画像 2 Logitech M215 Lens Replacement, Remove the battery cover: 手順 1、 3の画像 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    The battery lid lifts up from the back. It does not slide back.
    Bob Peters - 返信
    U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
    cconradmoore - 返信
    Thanks to u, i succeeded
    aresa0519 - 返信
  2. Logitech M215 Lens Replacement, Remove old battery: 手順 2、 1の画像 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    After replacing battery light goes on then off. I tried it twice. Do I need a new part.
    Elsie Sarkisian - 返信
    After replacing battery the remote green light goes on then off. I tried it twice
    What do u mean reverse order?
    The laser light did not go on
    Thank you this worked nicely
    - Reworld - - 返信
    Thanks for this!
    Tiara Dubb - 返信
  3. Logitech M215 Lens Replacement, Top Cover: 手順 3、 2の画像 1 Logitech M215 Lens Replacement, Top Cover: 手順 3、 2の画像 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Lens Replacement: 手順 4、 1の画像 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Lens Replacement, Motherboard: 手順 5、 2の画像 1 Logitech M215 Lens Replacement, Motherboard: 手順 5、 2の画像 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Lens Replacement, Lens: 手順 6、 2の画像 1 Logitech M215 Lens Replacement, Lens: 手順 6、 2の画像 2
    • The laser amplifier is not connected to the rest of the mouse and can simply be removed at this point.
終わりに
作成者
3人の作成者と共同で作成されました。
Hannah Pate
メンバー登録日: 01/30/15
1,722 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S1G1
4 メンバー
28のガイドは作成済み
コメント 1 件
Where i can buy mouse lenses for mk225
Cybermetz X - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 25
今までの合計 1,882
