はじめに
For this replacement you do not need any tools, however a prying tool may make the replacement easier.
Make sure that the mouse is turned off before replacing the battery. This will reduce the chance of damaging internal components with a surge of power from the new battery.
必要な工具と部品
The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
After replacing battery light goes on then off. I tried it twice. Do I need a new part.
After replacing battery the remote green light goes on then off. I tried it twice
What do u mean reverse order?
The laser light did not go on
Thank you this worked nicely
Thanks for this!
Tiara Dubb - 返信
28 の人々がこのガイドを完成させました。
10 件のコメント
I disassembled this exactly as stated and now I can't get the cover back on?
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
The green battery light went on, although the lazar light did not. What should I do?
I struggled to get the lid off until I realized that the lid lifts up from the back, it does not slide back. Once I found that out, it’s quite easy to open and close.
Bob Peters - 返信
great help ,easy when you know how
Tim OBrien - 返信
Your post is beneficial. I can follow it can change the battery of the M215. If you have any posts, I will read all of them because I'm spacebar clicker
The battery lid lifts up from the back. It does not slide back.
Bob Peters - 返信
U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
cconradmoore - 返信
Thanks to u, i succeeded
aresa0519 - 返信
