メインコンテンツにスキップ
Logitech M185 Wireless Mouse Scroll Wheel Replacement
必要な工具と部品
  1. Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 2 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 手順 1、 3の画像 3
    • Turn your mouse over so the bottom is facing up.
    • Slide the battery compartment door off to reveal the battery.
  2. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 2、 1の画像 1
    • Remove the battery.
    • Use a Phillips #00 screwdriver to remove the single screw in the battery compartment.
    • The screw may be hard to find at first, but it is directly under the battery.
  3. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 3、 3の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 3、 3の画像 2 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 3、 3の画像 3
    • Place one hand on the bottom of the mouse and the other on the top. Gently remove the top of the mouse.
  4. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 4、 2の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 4、 2の画像 2
    • Use a spudger and gently pry the motherboard up, to remove it from the mouse.
    • Any damage done to the board could affect the functionality of the mouse. Show EXTRA care when touching the board. Handle it along the edges only and wear ESD safe gloves if possible.
  5. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 5、 2の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 5、 2の画像 2
    • Carefully remove the scroll wheel from the motherboard.
  6. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 6、 1の画像 1
    • Insert the new scroll wheel.
  7. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 7、 3の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 7、 3の画像 2 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 7、 3の画像 3
    • Replace the motherboard.
    • Gently but firmly press down on it until it is securely in place.
    • You will hear a click or snap, indicating it is in place.
  8. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 8、 3の画像 1 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 8、 3の画像 2 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 8、 3の画像 3
    • Put the top of the mouse back onto the bottom and press them together so they connect.
    • Make sure the edges of the top and bottom of the mouse align so there is a secure connection.
    • Use a Phillips #00 screwdriver to replace the single screw in the battery compartment.
    • Replace the battery and battery cover.
  9. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 手順 9、 1の画像 1
    • Plug your mouse into a computer using the USB connector to ensure the scroll wheel is working.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Osame Osayande
メンバー登録日: 03/05/24
190 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 7-7, Grodsky Spring 2024 CSU Los Angeles, Team 7-7, Grodsky Spring 2024人のメンバー
CSULA-GRODSKY-S24S7G7
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 35
過去 30 日: 144
今までの合計 2,278
