はじめに
When the scroll wheel of your Logitech M125 mouse becomes worn or torn, it can prevent smooth motion when scrolling and needs replacement.
The scroll wheel allows you to navigate up and down on a web page or document. It also allows middle-clicking in programs that support it.
The housing in the mouse’s frame for the scroll wheel and the wheel spring are delicate. Be very careful not to over apply pressure, or you may risk damaging both the scroll wheel and the wheel spring.
Be sure to unplug your mouse before proceeding with this guide.
必要な工具と部品
Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
Once the screws are removed, open the mouse from the front as it pivots at the rear.
Insert a spudger between the left side of the scroll wheel and the housing. Then, rotate the spudger clockwise, so that it is pushing the center of the housing away from the wheel. Do this while pressing down on the wheel with your thumb.
