メインコンテンツにスキップ
Logitech K850 Disassembly
必要な工具と部品
  1. Logitech K850 Disassembly, Removing Batteries: 手順 1、 3の画像 1 Logitech K850 Disassembly, Removing Batteries: 手順 1、 3の画像 2 Logitech K850 Disassembly, Removing Batteries: 手順 1、 3の画像 3
    • Pry open the battery cover on the back of the device using either your hand or a spudger.
    • Use a spudger to remove the first battery.
    • Slide the 2nd battery out of the slot.
  2. Logitech K850 Disassembly, Unscrewing Screws: 手順 2、 3の画像 1 Logitech K850 Disassembly, Unscrewing Screws: 手順 2、 3の画像 2 Logitech K850 Disassembly, Unscrewing Screws: 手順 2、 3の画像 3
    • Unscrew the highlighted red screws using a Phillips 000 screwdriver.
    • Some screws are hidden under the rubber feet so you will have to pry off the rubber feet.
    • There are 2 screws under the keyboard's kickstand.
  3. Logitech K850 Disassembly, Separating The  Halves: 手順 3、 1の画像 1
    • Insert a spudger into the seam between the black side (front) and the white side (back).
    • Pry the two halves apart, making your way around the keyboard.
    • Be careful while prying, or else you may break the two plastic clips that hold the sides together.
  4. Logitech K850 Disassembly, Removing The Palm Rest: 手順 4、 2の画像 1 Logitech K850 Disassembly, Removing The Palm Rest: 手順 4、 2の画像 2
    • Flip the black side (front) over so the keys face downwards.
    • Remove the red highlighted screws, then remove the palm rest.
  5. Logitech K850 Disassembly, Unscrewing The Circuit Boards: 手順 5、 3の画像 1 Logitech K850 Disassembly, Unscrewing The Circuit Boards: 手順 5、 3の画像 2 Logitech K850 Disassembly, Unscrewing The Circuit Boards: 手順 5、 3の画像 3
    • Unscrew the circuit boards using a Phillips 000 screwdriver.
  6. Logitech K850 Disassembly, Freeing The Battery Connectors: 手順 6、 2の画像 1 Logitech K850 Disassembly, Freeing The Battery Connectors: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to bring the metal rods under and over the plastic hooks.
    • Approach with caution, you can break the metal rod and/ or the plastic hooks if you are too aggressive.
    • Unplug the ribbon cable connecting the two boards and remove the power switch daughter board.
    • Unplug the ribbon cable connecting the membrane to the main circuit board.
    • Peel off the membrane.
終わりに
The Logitech K850 keyboard is quite complex, though it is somewhat easy to fix. However, with a ton of fragile components that need to be pried on, repairs can be difficult.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Camuise
メンバー登録日: 11/22/18
1,603 ポイント
7のガイドは作成済み
3件のガイドコメント
How do I fix the incredibly tiny plastic piece where the foot/stand fits into? Are the side wholes enough to get two new feet without having to worry about that plastic part or does it need ot hook into that?
Danny Romero - 返信
It is difficult for key plucker to remove keys from.mk850 . Is there a easy way to remove keys from it?
Suman Kalyan - 返信
my space is ghost typing (automatically working) i opened and cleaned but still issue persist. any help would be appreciated.
tarun sharma - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 50
過去 30 日: 197
今までの合計 11,534
