メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Locate the battery tray near the top edge of the bottom side of the keyboard.  It is designed to be easy to insert but difficult to remove.
    • Locate the battery tray near the top edge of the bottom side of the keyboard. It is designed to be easy to insert but difficult to remove.
  2. Use a putty knife or metal spudger to pry the tray out.  Insert it into the gap along the bottom, then angle the handle to direct the force of the tip away from the body of the keyboard.  Tap as needed.
    • Use a putty knife or metal spudger to pry the tray out. Insert it into the gap along the bottom, then angle the handle to direct the force of the tip away from the body of the keyboard. Tap as needed.
  3. Once the "ears" past the edge, it should be easy to slide the tray the rest of the way out.
    • Once the "ears" past the edge, it should be easy to slide the tray the rest of the way out.
    • Note the battery type carefully: It is a ML2032, which is rechargeable. This is NOT the same as a CR2032, which is not rechargeable. Do Not replace with CR2032, as the solar panels will attempt to charge it.
    • Note the proper orientation of the battery (see picture), positive + symbol facing towards bottom. Negative side facing keys.
    • To make it easier to remove the battery in the future, trim the ears slightly or slice some notches in the plastic "springs" to weaken them a little.
終わりに
191 の人々がこのガイドを完成させました。
cityzen
メンバー登録日: 2010年05月03日
3,947 ポイント
2のガイドは作成済み
89 件のコメント
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - 返信
My sentiments, exactly!
Melinda Mcvay -
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - 返信
Thank You! That did work much better!
Matt Anderson -
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers -
コメントを追加
統計データを表示:
過去 24時間: 32
過去 7 日: 213
過去 30 日: 1,029
今までの合計 195,852
