メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Harmony 1100 Screen Replacement
必要な工具と部品
  1. Logitech Harmony 1100 Screen Replacement, How to Open Logitech Harmony 1100: 手順 1、 2の画像 1 Logitech Harmony 1100 Screen Replacement, How to Open Logitech Harmony 1100: 手順 1、 2の画像 2
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. Logitech Harmony 1100 Screen Replacement: 手順 2、 1の画像 1
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. Logitech Harmony 1100 Screen Replacement: 手順 3、 2の画像 1 Logitech Harmony 1100 Screen Replacement: 手順 3、 2の画像 2
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. Logitech Harmony 1100 Screen Replacement: 手順 4、 3の画像 1 Logitech Harmony 1100 Screen Replacement: 手順 4、 3の画像 2 Logitech Harmony 1100 Screen Replacement: 手順 4、 3の画像 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
  5. Logitech Harmony 1100 Screen Replacement, Screen: 手順 5、 1の画像 1
    • Pop out the plastic screen backing on front of device.
    • Loosen the screen backing by pushing back on the plastic clips that hold the screen backing in place.
  6. Logitech Harmony 1100 Screen Replacement: 手順 6、 2の画像 1 Logitech Harmony 1100 Screen Replacement: 手順 6、 2の画像 2
    • Use the PH00 Phillips head from the iFixit Tool Kit to remove the 3 screws from the circuit on the back half of the device.
    • Use the edge of the larger circuit board to flip the board over to the left.
    • The connector port in the top right corner may make removal difficult. Lift the logic board above the screw ports, and the connector port should slide out easily.
  7. Logitech Harmony 1100 Screen Replacement: 手順 7、 2の画像 1 Logitech Harmony 1100 Screen Replacement: 手順 7、 2の画像 2
    • Find the wire that attaches to the screen.
    • Push the dark grey bar that is used to lock the screen in place, outward from the beige bar to disconnect it.
    • Remove the screen wire.
ゴール
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Alex Turissini
メンバー登録日: 02/11/16
28 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Burgess Spring 2016 Ohio State, Team 1-5, Burgess Spring 2016人のメンバー
OSU-BURGESS-S16S1G5
4 メンバー
2のガイドは作成済み
1件のガイドコメント
Depending on the vintage of the original motherboard and new screen, you may find the replacement screen image is upside down. Activation points remain where they should be, not where the screen displays. There is no fix for this without the Harmony desktop software.
Ernst H Steinert - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 1,674
