メインコンテンツにスキップ
Logitech Harmony 1100 Logic Board Replacement
必要な工具と部品
  1. Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: 手順 1、 2の画像 1 Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: 手順 1、 2の画像 2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. Logitech Harmony 1100 Logic Board Replacement: 手順 2、 1の画像 1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. Logitech Harmony 1100 Logic Board Replacement: 手順 3、 2の画像 1 Logitech Harmony 1100 Logic Board Replacement: 手順 3、 2の画像 2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. Logitech Harmony 1100 Logic Board Replacement: 手順 4、 3の画像 1 Logitech Harmony 1100 Logic Board Replacement: 手順 4、 3の画像 2 Logitech Harmony 1100 Logic Board Replacement: 手順 4、 3の画像 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
  5. Logitech Harmony 1100 Logic Board Replacement, Screen: 手順 5、 1の画像 1
    • Pop out plastic screen backing on front of device.
    • Loosen screen backing by pushing back on plastic clips that are holding the black screen backing in place.
  6. Logitech Harmony 1100 Logic Board Replacement: 手順 6、 2の画像 1 Logitech Harmony 1100 Logic Board Replacement: 手順 6、 2の画像 2
    • Use PH00 Phillips head from the iFixit Tool Kit to remove 3 screws from the circuit on the back half of the device.
    • Flip over the larger circuit board to the left.
    • Use the edge of the circuit board to flip the board over.
    • The connector port in the top right corner may make removal difficult. Lift the logic board above the screw ports, and the connector port should slide out easily.
  7. Logitech Harmony 1100 Logic Board Replacement: 手順 7、 2の画像 1 Logitech Harmony 1100 Logic Board Replacement: 手順 7、 2の画像 2
    • Find the wire that attaches to the screen
    • Push dark grey bar that is used to lock the screen in place, outward from beige bar to disconnect.
    • Remove screen wire
  8. Logitech Harmony 1100 Logic Board Replacement, Logic Board: 手順 8、 2の画像 1 Logitech Harmony 1100 Logic Board Replacement, Logic Board: 手順 8、 2の画像 2
    • Push grey bar away from the beige bar
    • Remove button tab wire from logic board
  9. Logitech Harmony 1100 Logic Board Replacement: 手順 9、 3の画像 1 Logitech Harmony 1100 Logic Board Replacement: 手順 9、 3の画像 2 Logitech Harmony 1100 Logic Board Replacement: 手順 9、 3の画像 3
    • Lift on back of gold tab to unsecure positive and negative wires from device
    • Pull the gold buttons in towards the center of the device to detach logic board from case
ゴール
作成者
4人の作成者と共同で作成されました。
Chris Slack
メンバー登録日: 02/11/16
10 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Burgess Spring 2016 Ohio State, Team 1-5, Burgess Spring 2016人のメンバー
OSU-BURGESS-S16S1G5
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 870
