はじめに
Use this guide to replace a damaged or cracked controller case on your Logitech Gamepad F310. The controller case is what holds your controller together. That is reason to replace controller case.
Follow this guide in order to replace your Logitech Gamepad F310 controller case.
No special tools or skills required.
必要な工具と部品
終わりに
You have successfully taken the case off of your controller! Using the new case, follow these steps in reverse order to assemble your fixed controller.
