メインコンテンツにスキップ
Logitech G920 Driving Force Motor Motherboard Replacement
必要な工具と部品
  1. Logitech G920 Driving Force Motor Motherboard Replacement, Motor Motherboard: 手順 1、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 2、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 3、 2の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 3、 2の画像 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 4、 2の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 5、 2の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the four 13.5 mm screws with a Phillips #0 screwdriver.
  6. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 6、 2の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the pedals from both sides of the wheel base.
  7. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the three 36 mm screws with a Phillips #2 screwdriver.
  8. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 8、 3の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 8、 3の画像 2 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 8、 3の画像 3
    • Remove the wheel base from the motor box.
  9. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 9、 1の画像 1
    • Flip the motor box over.
    • Remove the twelve 12.2 mm screws with a Phillips #0 screwdriver.
    • Remove the two 11.5 mm screws with a Phillips #0 screwdriver.
  10. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 10、 2の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 10、 2の画像 2
    • Flip over the motor box once more.
    • Remove the motor box cover.
  11. Logitech G920 Driving Force Motor Motherboard Replacement: 手順 11、 3の画像 1 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 11、 3の画像 2 Logitech G920 Driving Force Motor Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the four 5 mm screws with a Phillips #0 screwdriver.
    • Detach the wires connected to the motherboard.
    • Remove the motherboard from the motor box.
終わりに
作成者
4人の作成者と共同で作成されました。
Aiden Muse
メンバー登録日: 09/12/23
477 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team 2-1, Harold Fall 2023 University of North Texas, Team 2-1, Harold Fall 2023人のメンバー
UNT-HAROLD-F23S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 54
過去 30 日: 277
今までの合計 1,042
