はじめに
Use this guide to remove and replace one of the G keys on the Logitech G915 TKL keyboard. A G key may need to be replaced if it's loose and not registering inputs properly, or simply broken for one reason or another.
A Phillips #00 Screwdriver is necessary to complete this guide.
必要な工具と部品
Remove the battery.
This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
Remove the remaining 2mm #00 Phillips back screws.
3 screws are hidden under the rubber rests of the keyboard.
ある他の人がこのガイドを完成しました。
2 件のコメント
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
