メインコンテンツにスキップ
Logitech G910 Power Cord Replacement
必要な工具と部品
  1. Logitech G910 Power Cord Replacement, Power Cord: 手順 1、 1の画像 1
    • Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
    INACCURATE; So far I have identified this keyboard has Seven backplate screws - three pictured, two opposite, two hidden beneath the extending blue element. How is the backplate removed?
    Stone Dauhg - 返信
    Yeah this doesn't seem right at all. They even show the PCB in the next pic. Clearly more screws. 7 across the top and 5 at least on the bottom. I still can't pullit open. Came here figuring I'd see what I'm missing.
    Jeffrey Scott - 返信
    Just for anyone else annoyed by the incredible lack of info. I think there are 15 screws. First unscrew the smaller bottom part which is the underneath of the palm rest. The left, middle, and right rubber feet there are concealing a screw each. Once that part is off it'll reveal 5 or 6 (can't remember exactly) that are part of the main back piece were trying to remove. Theres also two screws hidden by the blue slide-y thing.
    Regardless.... a few more than 3....
    WildLicorice - 返信
  2. Logitech G910 Power Cord Replacement: 手順 2、 1の画像 1
    • Remove the USB from the keyboard.
    holy crap you skipped a TON of steps
    Richard Baranski - 返信
  3. Logitech G910 Power Cord Replacement: 手順 3、 1の画像 1
    • Make sure the cord tab is not broken.
  4. Logitech G910 Power Cord Replacement: 手順 4、 1の画像 1
    • If the cord tab is not broken, close it back.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ahmed Al Hasan
メンバー登録日: 01/18/18
127 ポイント
1ガイドが承認済み
チーム
2 件のコメント
Hello,
Where can I find a replacement USB cord ?
My board works fine but sometimes disconnects before the power cable is really used. I just want to change that cable
pittetflavia - 返信
Yeah there is not problem replacing it but to find the cord itself. Cant seems to find replacement on the web.
LordGrizwold - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 73
今までの合計 4,945
