はじめに
This guide will help you remove a key from the keyboard. You'll want to use a plastic or metal spudger to remove the keys from the keyboard.
ツール
パーツ
パーツは指定されていません。
Turn the keyboard back and remove the screws from the front.
How should I remove the screws from under the faceplate when the next step is to remove the faceplate?
5 の人々がこのガイドを完成させました。
12 件のコメント
I am sorry, but why did you wrote a tutorial and describe how to open up G910 (and lose the warranty along the way) just to take of the keyCAP?
Keycap can be removed in a matter of seconds with use of $0.99 keycap removal tool
It’s not just the Key Cap, you can remove the mechanical switch too. I have a busted G910 and I’ve been wanting to replace the switches for a while now.
I think step 3 and 4 are in the wrong order, you can’t get to the screws until you get that face-plate off
Exactly. How do you get the face plate off? It's seems to be glued or double sided trapped and is cheap plastic that cracks easier than an egg!
this is the most pointless thing ive ever seen. you dont need to disassembe the keyboard to take the cap off you idiot.
this article is just to trick you into buying the tools required
what are the size of the screws? or where can i buy replacements?
