メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G603 Wheel Encoder Replacement
必要な工具と部品
  1. Logitech G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: 手順 1、 1の画像 1
    • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
  2. Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 手順 2、 3の画像 1 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 手順 2、 3の画像 2 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 手順 2、 3の画像 3
    • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
    • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
  3. Logitech G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: 手順 3、 1の画像 1
    • Use Phillips #00 to remove the four bottom screws
  4. Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 手順 4、 3の画像 1 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 手順 4、 3の画像 2 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 手順 4、 3の画像 3
    • Start at the top above the left and right click and slowly work your way around the shells until they are separated
    • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
  5. Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 手順 5、 3の画像 1 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 手順 5、 3の画像 2 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 手順 5、 3の画像 3
    • Start with the red and black power cable and gently pull it out
    • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
  6. Logitech G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: 手順 6、 1の画像 1
    • Gently pull out the black ribbon cable connecting the encoder board to the main board
  7. Logitech G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: 手順 7、 1の画像 1
    • Remove the Phillips #00 screws holding the encoder board in place
  8. Logitech G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: 手順 8、 1の画像 1
    • Remove the encoder board from the bottom shell
    • Gently remove the wheel from the older encoder board
    • NOTE: The old wheel can be reused in the replacement encoder board
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jim
メンバー登録日: 06/17/23
331 ポイント
2のガイドは作成済み
1件のガイドコメント
In my case, cleaning the encoder plate in an ultrasonic bath did the trick.
dobromir.dombek - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 56
過去 30 日: 219
今までの合計 5,819
