必要な工具と部品
If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
7 の人々がこのガイドを完成させました。
9 件のコメント
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda -
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel -
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Kobda -
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
