メインコンテンツにスキップ
Logitech G305 Scroll Wheel Replacement
必要な工具と部品
  1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 手順 1、 2の画像 1 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 手順 1、 2の画像 2
    この手順で使用する道具:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
  2. Logitech G305 Scroll Wheel Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four bottom case screws.
    • Caution, do not strip the head of the screws. These are not easily replaceable.
  3. Logitech G305 Scroll Wheel Replacement: 手順 3、 1の画像 1
    • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
    • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
    • Use caution when raising the outer shell—wires are still connected inside.
  4. Logitech G305 Scroll Wheel Replacement: 手順 4、 2の画像 1 Logitech G305 Scroll Wheel Replacement: 手順 4、 2の画像 2
    • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
  5. Logitech G305 Scroll Wheel Replacement: 手順 5、 1の画像 1
    • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
  6. Logitech G305 Scroll Wheel Replacement: 手順 6、 1の画像 1
    • Use a Phillips screw driver #00 to remove the four screws.
    • Be careful to not strip the screws, these can't be found at your local hardware store.
  7. Logitech G305 Scroll Wheel Replacement: 手順 7、 3の画像 1 Logitech G305 Scroll Wheel Replacement: 手順 7、 3の画像 2 Logitech G305 Scroll Wheel Replacement: 手順 7、 3の画像 3
    • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
    • Remove the motherboard out of the casing.
    • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
終わりに
10 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Nathan Rosales
メンバー登録日: 02/21/22
385 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-12, Smith Spring 2022 University of North Texas, Team 1-12, Smith Spring 2022人のメンバー
UNT-SMITH-S22S1G12
2 メンバー
3のガイドは作成済み
1件のガイドコメント
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 105
過去 30 日: 409
今までの合計 25,894
