メインコンテンツにスキップ
Logitech G27 Optical Encoder Replacement
必要な工具と部品
  1. Logitech G27 Optical Encoder Replacement, Steering Wheel: 手順 1、 1の画像 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Fijar primero el volante en la mesa para evitar desperfectos.
    Alpc360 - 返信
  2. Logitech G27 Optical Encoder Replacement: 手順 2、 1の画像 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Apoyar el volante con las piernas y sacar los tornillos.
    Alpc360 - 返信
  3. Logitech G27 Optical Encoder Replacement: 手順 3、 1の画像 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
  4. Logitech G27 Optical Encoder Replacement: 手順 4、 1の画像 1
    • Carefully remove the PCB board from the wheel hub.
  5. Logitech G27 Optical Encoder Replacement: 手順 5、 1の画像 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
    This works for the G27, not sure about the G25 or any other wheels.
    Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
    SouthernPotato - 返信
    bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
    Alexander - 返信
    @alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
    Okan Akgül - 返信
    okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
    Alexander -
    Where i can Buy the 7 pin cable for Main board please
    Ojilve jose - 返信
    Hey guys!
    i broke the 7 pin cable anyone know where can is buy it? Thanks
    Richard Hajdu - 返信
  6. Logitech G27 Optical Encoder Replacement: 手順 6、 1の画像 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
  7. Logitech G27 Optical Encoder Replacement: 手順 7、 1の画像 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
  8. Logitech G27 Optical Encoder Replacement: 手順 8、 1の画像 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    need two new black screes abouve the pcb board.. lost them need to know the size since the screws i replace it with was not exact..
    Alexander - 返信
    Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
    Oula Kuuva - 返信
  9. Logitech G27 Optical Encoder Replacement: 手順 9、 1の画像 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
    Oula Kuuva - 返信
    For removing C-Clamps steps 9-13 are unnecessary.
    Etam - 返信
  10. Logitech G27 Optical Encoder Replacement: 手順 10、 1の画像 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Some of the connectors have locks on them, I would recommend this as a two person job.
    Reuben Andrews - 返信
    I didn't take them off :)
    Evaristo Rivieccio Vega - 返信
    I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
    Felix Weschke - 返信
  11. Logitech G27 Optical Encoder Replacement: 手順 11、 1の画像 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
  12. Logitech G27 Optical Encoder Replacement: 手順 12、 1の画像 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
  13. Logitech G27 Optical Encoder Replacement: 手順 13、 2の画像 1 Logitech G27 Optical Encoder Replacement: 手順 13、 2の画像 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
  14. Logitech G27 Optical Encoder Replacement, Optical Encoder: 手順 14、 2の画像 1 Logitech G27 Optical Encoder Replacement, Optical Encoder: 手順 14、 2の画像 2
    • After following the prerequisite guide, invert your device.
    • Remove the four center-most screws from the bottom of the device with a Phillips #1 screwdriver.
    • Invert your device back to its original position, and completely remove the motor housing from the rest of the device.
  15. Logitech G27 Optical Encoder Replacement: 手順 15、 1の画像 1
    • Remove the eight screws attaching the metal motor housing to the plastic with a Phillips #1 screwdriver.
    • Completely remove the motor housing from the plastic.
    • In this picture, the optical encoder is attached to the end of the right-most motor. It has a black plastic case around it for protection.
    I found the repair easier to do with the motor still attached to the housing, step 15-16 unnecessary.
    Justus Cucuro - 返信
  16. Logitech G27 Optical Encoder Replacement: 手順 16、 1の画像 1
    • Turn the device around, and remove the three screws attaching the left most motor to the metal backing using a Phillips #1 screwdriver.
    • Completely remove the motor from the metal backing. This will make it easier to move around when replacing the optical encoder.
    Justus Cucuro - 返信
  17. Logitech G27 Optical Encoder Replacement: 手順 17、 2の画像 1 Logitech G27 Optical Encoder Replacement: 手順 17、 2の画像 2
    • Remove the white 5-pin adapter from the end of the optical encoder.
    • Use the same amount of caution with this adapter as you did with all the others: don't pull directly on the wires and wiggle it out.
    • Remove the plastic casing by prying it off with a screwdriver or a plastic opening tool.
    bonsoir ou acheter les conecteur blanc avec les 5 fils pour volant g27
    philippegontier30@free.fr - 返信
    ou acheter les connecteur blanc avec les 5 fils de couleur du volant g27
  18. Logitech G27 Optical Encoder Replacement: 手順 18、 1の画像 1
    • Remove the two silver screws from the underside of the optical encoder with a Phillips #0 screwdriver, and the circuit will be free from the motor and ready to replace!
    • Be careful not to bend the light or the black receiver that stick up off the board. If they don't line up, your wheel won't be able to calibrate at all and you'll have a very hard time trying to line them back up.
    my wheel wont calibrate and sometimes it spits out a “power surge on usb” error and my optical encoder is good, what do i do?
    Jackson Beers - 返信
    I like this replacement. https://es.aliexpress.com/item/329959435...
    At first I didn't calibrate myself. I realised that it has to be fully inserted and satin with the end of the motorbike cylinder, as you can see in the seller's pictures. Then it did calibrate.
  19. Logitech G27 Optical Encoder Replacement: 手順 19、 3の画像 1 Logitech G27 Optical Encoder Replacement: 手順 19、 3の画像 2 Logitech G27 Optical Encoder Replacement: 手順 19、 3の画像 3
    • During reinstallation make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
    • Also make sure that the metal half-circle clip is placed properly inside the slot.
    • After placing the metal clip in the slot, place the plastic cog on top of the clip and on the rail.
    Step 19: If you disassembled the wheel with the wheel in center position, you have to re-assemble it with the gear in center position, not as shown on the picture. At least this is what worked perfectly for me on the G27! While disassembling, I paid attention that everything keeps in center position.
    Philipp H - 返信
    There is also small dot on the gear and small arrow on the track that represent the middle, I would say that this is more accurate method. (on G25)
    Vojtěch H - 返信
    There is a Timing mark on the face of the linear gear and the round gear, line the timings dots together
    Justus Cucuro - 返信
終わりに
49 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Grant Blake
メンバー登録日: 04/21/15
1,677 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015人のメンバー
CPSU-AMIDO-S15S15G4
4 メンバー
25のガイドは作成済み
29 件のコメント
Where can you get the encoder to replace it?
invertig0 - 返信
Hello and thanks for the guide. I understand this might be off topic, but would you happen to know the pinout of the7-pin connector in step 5? There is no label on the pins. Thanks in advance for your time.
Georgios Arkouzis - 返信
Very much appreciate your assistance & time putting this together. I Chose the expoxy route. My wheel IS BACK!
Dave - 返信
Are you sure about Step 19 alignment. Some other guy with G25 says it has to be dead centre alligned otherwise you get blinking lights.And that's exactly what happens to me.
robertleskovsek - 返信
hi! i reassembled mine positioning it all the way to the right, and i have blinking power light and my wheel do not calibrate. what do you mean by dead centre aligned? i have to assemble it back together in center position, is that it?
felipezerobala -
Hey, really big thanks for this guide! I opened my wheel and found the optical encoder broken as foreseen. Just bought the brass version, but for the first instance I fixed the encoder by wrapping some thin tape around the edges and cut off the rest. worked well, but is not meant for a long time use.
As I managed to make this fault, please add a hint that when rearranging the wheel (reverse step 1+2 the thin wheel button wires love to slip close to the bottom left and right screwholes with the risk to be squezzed between wheel and wheel hub. Now I have repaired the wheel function and wrecked the upper left button function :-)
fulgorth - 返信
Gracias a esta guía he podido reparar el volante G27. Muchas gracias.
urrielu - 返信
You can buy a printed version here: https://www.shapeways.com/product/4FDSWS...
It worked great for me, it shipped within a week and I'm using it now for over 2 years without any problems.
2 versions are sold: 30 and 60 slot encoder.
60 slot is for G25 and early G27 later G27 wheels use the 30 slot version.
RacingVictim - 返信
The three hub screws in step 6 refused to go all the way back in, and one of them stripped completely. If this happens to you, you can get shorter screws here to replace those very long screws - https://www.amazon.com/gp/product/B01MFA...
Also the best replacement in terms of longevity for the encoder disk is the brass ones that you can order here, but shipping takes quite a while - http://cmlaserservice.com/index.html
I tried to 3D print one myself but it didn't work.
SouthernPotato - 返信
Hello, i repaired the old optical encoder. Now when i connect my wheel to PC the calibration works. But then PC doesn't "read" when im stearing. The other buttons are ok. Please help me what to do. Thanks
Tom Bubok - 返信
can you please share me the motor specifications?
Gokulraj S - 返信
Is this questin for me?
Tom Bubok -
yeah ! I need this motor specifications :)
Gokulraj S -
Repaired with this guide, thanks.
For the repair of the optical encoder I used a washer.
smigolxp - 返信
not encoder?? Washer??
Il Vloggatore -
is it work sameway??
Il Vloggatore -
I user a washer to repair the broken optical encoder.
smigolxp -
Excellent guide and thanks for the publication and your help !!!
Luca Ragno - 返信
!!!!Took me a white 2FIX it but!!! LISTEN! !!If Your wheel aiant straight in center with good or new encoder TRY first in windows controllers menu .Wherę IT shows controler. Devices while pointing at your g25,7dfgt Device :Press Ctr+shift and right Mouse to engage wheel calibration. Thank you and You Welcome ;)
laikros - 返信
Hi everyone. You can buy a replacement from there. Optical encoders available with 30 or 60 Slot. For 30 Slot check out this https://www.ebay.com/itm/264059488231 and for 60 Slot check out this https://www.ebay.com/itm/264059495927
Mister - 返信
Also I have managed to change the encoder without disassembling the mainboard and bearing housing. Just remove the motor encoder cover and change the encoder. The same way worked on Driving Force GT
Mister - 返信
Where can I order the optical IR sensor? I’m not getting my drive on without one …
DieCalmerThanASuicideBomber - 返信
If someone tries do do this: Do not do step 9 to 16. It’s completely unnecessary and will just make it harder to assemble again. You can remove the cable and casing as described in step 17 just fine with some fiddling.
If you disassemble it completely as shown in this guide you will have to align the stop gear to the track again (step 19), which just doesn’t work well by visual estimate alone.
Viking Dinosaurs - 返信
Hello
I changed my optical wheel, but after that my g27 doesn’t calibrate : power led is blinking, but the wheel doesn’t make its calibration process as the wheel is not moving… After three attempts, power led is blinking fast and that’s all.
I made a video of this problem : https://youtu.be/hihREK_QC1Q
I thought my optical wheel was too low (or too high) on the engin axis, so I tried to change its position but no effect.
If you have any idea…
Sylvain Jn - 返信
I had the same issue. If you have a 3d-printed optical wheel replacement make sure to completely cover it with black marker. It has to be all the way black otherwise light can shine through the spokes and the encoder sends an error which results in the issue you’re having.
So even if it looks black.. just try again with the black marker..
Don H -
how many slot encoder do i need?
Nico Rosella - 返信
Step 15 and 16 can be skipped! You can keep the motors attached to the frame to open up and replace the encoder wheel. (I just did it like that and that works fine)
Don H - 返信
Good day sir
I have lost the 5 pin adapter
Please help me i am unable to find 5-pin adapter for encoder part online
I want to purchase it
DeadShoT World - 返信
Hey,
I switched the encoder on my g27 with a brass one yet I'm facing another issue. With the old broken encoder, it only calibrated to the right. With the new one, It calibrates all the way from right to left but it doesn't come back to the center. Then it repeats the process 3 times but nothing happens. What could be the issue?
I've read people saying that I need to readjust the black plastic to the center on step 19.. any ideas?
Hannod - 返信
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 120
過去 30 日: 646
今までの合計 85,046
