メインコンテンツにスキップ
Logitech G27 Internal Motors Replacement
必要な工具と部品
  1. Logitech G27 Internal Motors Replacement, Steering Wheel: 手順 1、 1の画像 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
  2. Logitech G27 Internal Motors Replacement: 手順 2、 1の画像 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
  3. Logitech G27 Internal Motors Replacement: 手順 3、 1の画像 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
  4. Logitech G27 Internal Motors Replacement: 手順 4、 1の画像 1
    • Carefully remove the PCB board from the wheel hub.
  5. Logitech G27 Internal Motors Replacement: 手順 5、 1の画像 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
  6. Logitech G27 Internal Motors Replacement: 手順 6、 1の画像 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
  7. Logitech G27 Internal Motors Replacement: 手順 7、 1の画像 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
  8. Logitech G27 Internal Motors Replacement: 手順 8、 1の画像 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
  9. Logitech G27 Internal Motors Replacement: 手順 9、 1の画像 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
  10. Logitech G27 Internal Motors Replacement: 手順 10、 1の画像 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
  11. Logitech G27 Internal Motors Replacement: 手順 11、 1の画像 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
  12. Logitech G27 Internal Motors Replacement: 手順 12、 1の画像 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
  13. Logitech G27 Internal Motors Replacement: 手順 13、 2の画像 1 Logitech G27 Internal Motors Replacement: 手順 13、 2の画像 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
  14. Logitech G27 Internal Motors Replacement, Internal Motors: 手順 14、 3の画像 1 Logitech G27 Internal Motors Replacement, Internal Motors: 手順 14、 3の画像 2 Logitech G27 Internal Motors Replacement, Internal Motors: 手順 14、 3の画像 3
    • Remove the four 12.2mm screws using the Phillips screw driver.
    • The motors and gear box should now slide out. As you take it out, the metal spring band as well as the track for the wheel gear will also slide off.
    • During reinstallation, make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
    • When you have separated these parts, you can set them aside until reassembly.
  15. Logitech G27 Internal Motors Replacement: 手順 15、 1の画像 1
    • Next remove the eight 15.8mm screws that connect the plate holding the motors to the gear box.
    • When separating the gear box from the motor plate and motors be sure the gears do not fall out as they are difficult to put back in.
  16. Logitech G27 Internal Motors Replacement: 手順 16、 2の画像 1 Logitech G27 Internal Motors Replacement: 手順 16、 2の画像 2
    • Remove the six 7.4mm screws that attach the motors to the motor plate and slide the motors off the motor plate.
    • The motor plate can be set aside and the motors can now be replaced.
終わりに
19 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Max Barta
メンバー登録日: 04/21/15
583 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015人のメンバー
CPSU-AMIDO-S15S15G4
4 メンバー
25のガイドは作成済み
7件のガイドコメント
Where can I buy this motors?
arthuru59 - 返信
If you do not feel confident doing this yourself, here is a link to a company that could do it for you http://www.mz-simulators.co.uk/services....
Okiura - 返信
Where can i buy this motors ?
onnepultrum - 返信
You can buy the motors from eBay :)
S2 KTS. - 返信
i found 1 of each
going to buy the encoder as well and start with it and then motors if needed
Jeff Bauer - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 75
過去 30 日: 330
今までの合計 59,898
