はじめに
If the C-Clamps on your Logitech G27 break, you will need to replace them before using the steering wheel again. This is a little bit of a pain to do, because the C-Clamps are fully inside the device case. To replace them, you will just need to remove a few screws.
必要な工具と部品
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
Carefully pinch and unplug the large 7-pin connector under the PCB board.
These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
This works for the G27, not sure about the G25 or any other wheels.
Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
@alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
Okan Akgül - 返信
okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
Where i can Buy the 7 pin cable for Main board please
Hey guys!
i broke the 7 pin cable anyone know where can is buy it? Thanks
Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
The housing cover can be set aside until you put the wheel back together.
Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
Oula Kuuva - 返信
Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
Oula Kuuva - 返信
Unplug the three plastic connectors on the left side of the PCB board.
Unplug the two plastic connectors on the top of the PCB board.
Unplug the three plastic connectors on the right side of the PCB board.
Some of the connectors have locks on them, I would recommend this as a two person job.
I didn't take them off :)
I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
23 の人々がこのガイドを完成させました。
14 件のコメント
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Look for it at eBay.
Eduardo -
I also need to find a place to buy replacement C-clamps from
Agree. Skip from step 8 to 14 directly.
Great tutorial though, cannot make it better! Thanks for putting this together!
Eduardo -
You are absolutely correct. 9-13 are totally unrelated to changing the C-clamp.
Thanks a lot, mate.
Hi did not need step 9-14 as was able to push the clamp from the bottom of the steering wheel saving time and the risk of damaging cables
Great guide! The new clamps can be 3D printed. https://www.thingiverse.com/thing:179714...
Improved Logitech Clamps can be found here. Made with stronger material, holds and weights more. Check it out: https://www.ebay.com/itm/263522953969 . Thank you for looking
Anyone know where to get a 3D print of the Logitech G27 "Shifter Center Desk Clamp & Screw".
In other words where can I get the full assembley to secure the shifter to the desk, thanks.
Fijar primero el volante en la mesa para evitar desperfectos.
Alpc360 - 返信
