はじめに
Replacing the Wi-Fi chips for the Logitech G Cloud is simple and can be accomplished in six steps. You will need a wedge tool and a Phillips #00 screwdriver. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the interior plating. There are Wi-Fi chips on the top and bottom of the device labeled "WiFi". Once the screws are removed, the Wi-Fi chips should be easy to pop out.
必要な工具と部品
Power the device off and turn it over so the screen is face down.
Insert an opening pick into the seam between the back plate and left handguard.
Pry around the entire perimeter until the handguard fully releases.
Remove the handguard.
Repeat the previous three bullets on the right handguard.
Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the Wi-Fi chips located on the top and bottom of the device.
Pop the Wi-Fi chips out with your fingers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
