メインコンテンツにスキップ
Logitech G Cloud Battery Replacement
必要な工具と部品
  1. Logitech G Cloud Battery Replacement, Case: 手順 1、 2の画像 1 Logitech G Cloud Battery Replacement, Case: 手順 1、 2の画像 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Battery Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Battery Replacement: 手順 3、 2の画像 1 Logitech G Cloud Battery Replacement: 手順 3、 2の画像 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Battery Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Battery Replacement: 手順 5、 2の画像 1 Logitech G Cloud Battery Replacement: 手順 5、 2の画像 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Battery Replacement, Battery: 手順 6、 3の画像 1 Logitech G Cloud Battery Replacement, Battery: 手順 6、 3の画像 2 Logitech G Cloud Battery Replacement, Battery: 手順 6、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    • Insert the flat end of a spudger under the edge of the battery press connector and lift straight up to disconnect it.
    • Insert an opening tool under the bottom edge of the battery. Gently and slowly lift straight up to separate the adhesive on the battery from the console.
    • Take care not to bend, warp, or puncture the battery.
    • If your replacement battery doesn't come with adhesive, use a strong double-sided adhesive to secure it.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
3人の作成者と共同で作成されました。
Spencer Davis
メンバー登録日: 01/23/25
517 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Spring 2025 Western Carolina University, Team 1-1, Virtue Spring 2025人のメンバー
WCU-VIRTUE-S25S1G1
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 30
今までの合計 289
