メインコンテンツにスキップ
Logitech Extreme 3D Pro Disassembly of the handle
必要な工具と部品
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: 手順 1、 1の画像 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: 手順 2、 1の画像 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: 手順 3、 2の画像 1 Logitech Extreme 3D Pro Disassembly of the handle: 手順 3、 2の画像 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
終わりに
6 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Emanuel Canela
メンバー登録日: 01/25/18
1,369 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S7G1
4 メンバー
7のガイドは作成済み
3件のガイドコメント
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - 返信
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
reassembling is tricky. The spring tabs for z-rot need to be aligned on one side of the handle and the z-rot potentiometer needs aligning on the other. There is nothing obvious in the handle design to guide the correct positioning. The difficult part is getting the pot tab to stay in its slot. If anyone knows of a technique to assist getting the handles halves and pot in the correct alignment, please do tell.
memar - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 47
今までの合計 4,422
