メインコンテンツにスキップ
Logitech Circle Speaker Replacement
必要な工具と部品
  1. Logitech Circle Speaker Replacement, Speaker: 手順 1、 2の画像 1 Logitech Circle Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: 手順 2、 1の画像 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: 手順 3、 2の画像 1 Logitech Circle Speaker Replacement: 手順 3、 2の画像 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: 手順 4、 2の画像 1 Logitech Circle Speaker Replacement: 手順 4、 2の画像 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: 手順 5、 2の画像 1 Logitech Circle Speaker Replacement: 手順 5、 2の画像 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: 手順 6、 2の画像 1 Logitech Circle Speaker Replacement: 手順 6、 2の画像 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: 手順 7、 1の画像 1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: 手順 8、 1の画像 1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
終わりに
作成者
2人の作成者と共同で作成されました。
Emma Cochran
メンバー登録日: 09/28/17
110 ポイント
1ガイドが承認済み
チーム
University of Maine, Team S1-G4, Diaz Fall 2017 University of Maine, Team S1-G4, Diaz Fall 2017人のメンバー
UMAINE-DIAZ-F17S1G4
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 10
今までの合計 352
