メインコンテンツにスキップ
Logitech Circle Ribbon Cable Replacement
必要な工具と部品
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: 手順 1、 2の画像 1 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: 手順 1、 2の画像 2
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Ribbon Cable Replacement: 手順 2、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 2、 2の画像 2
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Ribbon Cable Replacement: 手順 3、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 3、 2の画像 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Ribbon Cable Replacement: 手順 4、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 4、 2の画像 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Ribbon Cable Replacement: 手順 5、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 5、 2の画像 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Ribbon Cable Replacement: 手順 6、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 6、 2の画像 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Ribbon Cable Replacement: 手順 7、 3の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 7、 3の画像 2 Logitech Circle Ribbon Cable Replacement: 手順 7、 3の画像 3
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
  8. Logitech Circle Ribbon Cable Replacement: 手順 8、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 8、 2の画像 2
    • Gently pull the ribbon cable loose from its connection to the base.
  9. Logitech Circle Ribbon Cable Replacement: 手順 9、 2の画像 1 Logitech Circle Ribbon Cable Replacement: 手順 9、 2の画像 2
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
  10. Logitech Circle Ribbon Cable Replacement: 手順 10、 1の画像 1
    • Remove the black plastic connector and the two springs from the base of the device.
  11. Logitech Circle Ribbon Cable Replacement: 手順 11、 1の画像 1
    • Reach inside the circle and pull the ribbon cable free from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Haley Williams
メンバー登録日: 09/28/17
112 ポイント
1ガイドが承認済み
チーム
University of Maine, Team S1-G4, Diaz Fall 2017 University of Maine, Team S1-G4, Diaz Fall 2017人のメンバー
UMAINE-DIAZ-F17S1G4
3 メンバー
8のガイドは作成済み
6件のガイドコメント
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - 返信
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - 返信
Can you advise where to buy the correct cable?
Michele Ingratta - 返信
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - 返信
i also need that cable
l_samin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 27
今までの合計 2,352
