メインコンテンツにスキップ
Logic Board Duplicate Guide
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Logic Board Duplicate Guide, Logic Board: 手順 1、 2の画像 1 Logic Board Duplicate Guide, Logic Board: 手順 1、 2の画像 2
    • Face the phone's back cover towards you. Press the oval-shaped button located at the bottom of the cover.
    • While holding this button, slide the back cover off. This should expose the battery.
  2. Logic Board Duplicate Guide: 手順 2、 1の画像 1
    • Pull the battery out of the phone and set it aside.
  3. Logic Board Duplicate Guide: 手順 3、 2の画像 1 Logic Board Duplicate Guide: 手順 3、 2の画像 2
    • Identify the four screw locations.
    • Use a torx screwdriver to unscrew the four screws located on the back of the phone. In order to unscrew a screw, insert your screwdriver into a screw and rotate the screwdriver counterclockwise.
    • Once each of the screws are removed, set them aside.
  4. Logic Board Duplicate Guide: 手順 4、 1の画像 1
    • Unscrew the antenna by twisting it counterclockwise.
  5. Logic Board Duplicate Guide: 手順 5、 1の画像 1
    • Remove the back cover by identifying a line of separation between the front and back of the phone.
    • Pull on both sides of the phone, front and back, in opposite directions. This will remove the back cover and reveal the logic board.
  6. Logic Board Duplicate Guide: 手順 6、 2の画像 1 Logic Board Duplicate Guide: 手順 6、 2の画像 2
    • Identify the orange strip attached to the upper right hand corner of the logic board.
    • Detach this strip by pulling it off of the logic board but not off the phone itself. This will then enable you to pull your logic board off.
    • Pay attention to the orientation of the logic board as you will use this same orientation when you insert the new logic board.
  7. Logic Board Duplicate Guide: 手順 7、 1の画像 1
    • Attach your new logic board to the orange strip by pushing it on to the new logic board. Set the logic board back in the phone casing.
終わりに
作成者
8人の作成者と共同で作成されました。
iDeleted
メンバー登録日: 07/07/10
2,101 ポイント
39のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,152
