メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Has your disco ball stopped rotating and turned into a weird, multi-colored lamp? Use this guide to avoid the party-foul and get that ball spinning!
パーツ
  1. Turn the device over so that the base is on top.
    • Turn the device over so that the base is on top.
  2. Peel off the piece of metal that is glued to hold the two halves of the base together.
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  5. Use a pair of tweezers to crush the sides of the wirenuts. The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  6. Separate the wires that belong to the motor. The wires should be small and black.
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
終わりに
To reassemble your device, follow these instructions in reverse order, starting from step five.
ある他の人がこのガイドを完成しました。
Courtney Elliott
メンバー登録日: 2014年01月14日
360 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014人のメンバー
CPSU-FORTE-W14S17G3
5 メンバー
7のガイドは作成済み
2 件のコメント
Where can you find a replacement motor?
bellyjb - 返信
I can't find one either!!!!
Dallin - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,665
