メインコンテンツにスキップ
Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement
必要な工具と部品
  1. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: 手順 1、 1の画像 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 手順 2、 3の画像 1 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 手順 2、 3の画像 2 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 手順 2、 3の画像 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 手順 3、 1の画像 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: 手順 4、 2の画像 1 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: 手順 4、 2の画像 2
    • Unscrew the burnt-out light bulb with a counter-clockwise twist.
    • Do not apply too much pressure when unscrewing light bulb, as the light bulb may break.
ゴール
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nick Kaprielian
メンバー登録日: 01/14/14
525 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014人のメンバー
CPSU-FORTE-W14S17G3
5 メンバー
7のガイドは作成済み
4 件のコメント
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - 返信
Saved me a headache. Couldn't figure out how to remove base. Thanks!
mccullough1251 - 返信
Helpful guide. Thank you.
In case there is any confusion, all you have to do is push in that tab on one side and lift. No twisting necessary. Also, the other side will come off.
jgprus - 返信
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
Melissa Fleming - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 61
今までの合計 15,403
