この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your disco ball not giving off the right groovy colors that it once did? This guide will teach you how to replace the colored panels so you can get back to partying!
必要な工具と部品
Turn the device over, so that the base is on top.
Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
Insert a new color panel by pushing it into place while lining up the tabs with the notches.
もう少しです!
終わりに
