このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
If you are using the unpackaged linux version you should place these files someplace on your path.
There are several various linux distro specific packaged versions which you may want to investigate. See notes at bottom of guide.
Mac and Windows have clickable install packages.
You can also use this software on a chromebook if you have installed crouton/linux and follow the steps needed for a linux install in the crouton chroot of your choice. If you have experience with the xiwi functionality you can make it almost seamless with the chromebook user interface!
22 の人々がこのガイドを完成させました。
2 件のコメント
vief,
There are literally thousands of bootable iso images on the internet. All shapes and sizes, architectures and whatever. What they do is up to the producers of the images. Some will only run on certain types of hardware etc. I am referring to linux distribution isos primarily here. But there are also standalone games and many other types. The so-called live linux CDs/DVDs that allow you to "test drive" a distribution before committing to installing are another popular boot image. If this does not clarify it for you feel free to ask again. I used google translate to see an english translation so hopefully your question did not get lost in translation. :D
