メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Linux - Mac - Windows creating bootable images on USB keys - SD cards the easy way.
  1. FixBotに聞いてみる
    コメントを追加
    • At a shell prompt typically on debian systems: sudo apt-get install fuse
    FixBotに聞いてみる
    コメントを追加
    • it will be completely cleared and rewritten with the iso image contents of course so if you have anything you want to keep on it you should have already saved that data elsewhere.
    FixBotに聞いてみる
    コメントを追加
    • If you are using the unpackaged linux version you should place these files someplace on your path.
    • There are several various linux distro specific packaged versions which you may want to investigate. See notes at bottom of guide.
    • Mac and Windows have clickable install packages.
    • You can also use this software on a chromebook if you have installed crouton/linux and follow the steps needed for a linux install in the crouton chroot of your choice. If you have experience with the xiwi functionality you can make it almost seamless with the chromebook user interface!
    FixBotに聞いてみる
    コメントを追加
  2. Linux - Mac - Windows creating bootable images on USB keys - SD cards the easy way., Point the Etcher software at any bootable *.iso image: 手順 5、 1の画像 1
    • Click blue button in picture for selection dialog.
    FixBotに聞いてみる
    コメントを追加
  3. Linux - Mac - Windows creating bootable images on USB keys - SD cards the easy way., Select the device to be flashed: 手順 6、 1の画像 1
    • If you only have a single such device connected you can skip to next step.
    • If you have multiple devices connected the red button pictured will open a dialog that allows you to select the device you want to create the bootable iso to.
    FixBotに聞いてみる
    コメントを追加
  4. Linux - Mac - Windows creating bootable images on USB keys - SD cards the easy way., Click "flash" button to proceed.: 手順 7、 1の画像 1
    • Your device will be overwritten with the now bootable USB image. See blue button in picture.
    • Or just close the window with "X" if you change your mind.
    FixBotに聞いてみる
    コメントを追加
    • When the image is ready you are presented option dialog to allow you to create multiple copies if desired.
    • Or you can just close with 'X' if you only need a single device create.
    FixBotに聞いてみる
    コメントを追加
終わりに
My Advice
You can also go the tuxboot/rufus route (google it) but honestly why would you want to. There is an ifixit guide for using the rufus route also here: USB Installation Media Creation
PS: There are linux distro specific packaged installation files and instructions for use of each here:
https://github.com/resin-io/etcher
Looks towards the bottom of the page under the "Installers" heading.
キャンセル: このガイドを終了できませんでした。
23 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
tcagle53
メンバー登録日: 06/18/14
8,778 ポイント
11のガイドは作成済み
チーム
Chromebook Cowboys Chromebook Cowboys人のメンバー
Community
4 メンバー
50のガイドは作成済み
2件のガイドコメント
ik heb zelf linux maar ik begrijp de titel al niet. Gaat het wel om afbeeldingen? wat is het doel van deze actie? Wordt de ssd kaart leesbaar op zowel mac als linux als windows? of slechts éen van de drie?
vief - 返信 共有
vief,
There are literally thousands of bootable iso images on the internet. All shapes and sizes, architectures and whatever. What they do is up to the producers of the images. Some will only run on certain types of hardware etc. I am referring to linux distribution isos primarily here. But there are also standalone games and many other types. The so-called live linux CDs/DVDs that allow you to "test drive" a distribution before committing to installing are another popular boot image. If this does not clarify it for you feel free to ask again. I used google translate to see an english translation so hopefully your question did not get lost in translation. :D
tcagle53 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 49
過去 30 日: 191
今までの合計 12,173
