メインコンテンツにスキップ
Linksys e1200 wireless router Maintenance to Prevent Overheating
必要な工具と部品
  1. Linksys e1200 wireless router Maintenance to Prevent Overheating, Linksys e1200 wireless router Maintenance to Prevent Overheating: 手順 1、 1の画像 1
    • The router is made with ambient air vents that operate on convection. As the router heats up from activity, warm air moves out of the router, to be replaced by cooler air. Dust, dirt, & grime limit the effectiveness of the cooling, causing the circuit board to heat up and break down & fail faster.
    • Simply use some compressed air to force accumulated dirt out through to the other sides.
  2. Linksys e1200 wireless router Maintenance to Prevent Overheating: 手順 2、 1の画像 1
    • Placement of the device is of great importance. Make sure to place it in an area free of activity so the device does not fall or get damaged.
    • Do not place it on top of a computer, television or any area that produces heat. Do not place it below a desk or an area where dirt and dust accumulate.
    • Do not place on top of an air vent because they spit out duct and accumulate within the device.
    • Do not place anything on top of the device.
終わりに
作成者
5人の作成者と共同で作成されました。
Tahisha Hicks
メンバー登録日: 02/24/14
409 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 5-4, Lauer Spring 2014 Michigan Tech, Team 5-4, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G4
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,104
