メインコンテンツにスキップ
Linksys WRT54GS v2 Rear Case Replacement
必要な工具と部品
  1. Linksys WRT54GS v2 Rear Case Replacement, Front Case: 手順 1、 1の画像 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Rear Case Replacement: 手順 2、 1の画像 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Rear Case Replacement: 手順 3、 1の画像 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Rear Case Replacement: 手順 4、 1の画像 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Rear Case Replacement, Motherboard: 手順 5、 1の画像 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Rear Case Replacement: 手順 6、 1の画像 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Rear Case Replacement, Rear Case: 手順 7、 1の画像 1
    • Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
    • Once you complete this step, your router will be completely disassembled.
終わりに
作成者
3人の作成者と共同で作成されました。
Allian Roman
メンバー登録日: 10/12/11
276 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,465
