メインコンテンツにスキップ
はじめに
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
パーツ
パーツは指定されていません。
  1. Linksys WRT54G Motherboard Component Replacement, Antennas: 手順 1、 1の画像 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Component Replacement: 手順 2、 3の画像 1 Linksys WRT54G Motherboard Component Replacement: 手順 2、 3の画像 2 Linksys WRT54G Motherboard Component Replacement: 手順 2、 3の画像 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Component Replacement: 手順 3、 3の画像 1 Linksys WRT54G Motherboard Component Replacement: 手順 3、 3の画像 2 Linksys WRT54G Motherboard Component Replacement: 手順 3、 3の画像 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Component Replacement, Casing: 手順 4、 2の画像 1 Linksys WRT54G Motherboard Component Replacement, Casing: 手順 4、 2の画像 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Component Replacement, Motherboard: 手順 5、 2の画像 1 Linksys WRT54G Motherboard Component Replacement, Motherboard: 手順 5、 2の画像 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Component Replacement: 手順 6、 2の画像 1 Linksys WRT54G Motherboard Component Replacement: 手順 6、 2の画像 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Component Replacement: 手順 7、 1の画像 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
  8. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: 手順 8、 1の画像 1
    • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (はんだ付けとはんだ除去の作業ガイド).
    • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
  9. Linksys WRT54G Motherboard Component Replacement: 手順 9、 2の画像 1 Linksys WRT54G Motherboard Component Replacement: 手順 9、 2の画像 2
    • Identify the functional component which will be removed.
    • Turn the board over so that the pins holding the component in are exposed.
  10. Linksys WRT54G Motherboard Component Replacement: 手順 10、 1の画像 1
終わりに
ある他の人がこのガイドを完成しました。
Nicole C
メンバー登録日: 2011年10月12日
102 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G7
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 3,644
